With a closed loop system I'd aim for the upper end of the spectrum if you can easily enough find a pump that gets you there. From reviews I've read, people have said you can't run that harbor freight pump continuously. You probably know that already though. What about the computer pump that Gary used on his domestic hot water loop? Its pretty inexpensive and has worked out well for him. Here they are: Swiftech - Pumps
Newegg.com has better prices on them.
I even have one hanging around if you'd like to try it out.
