re the "efficiency" of convection ovens. The air temp in a convection oven is set with a 25 degree F offset compared to a conventional oven. This is because the convection oven heats food faster.
The reason is the infamous "stirred static layer". In a conventional oven, the hot air tries to infiltrate the food, but there is a layer of cool air immediately surrounding the food, less than 1 mm or so. The convection oven fan disturbs this and smears this layer so the existing heat gets into the food faster.
Steve
