Xringer,
This morning the outside temperature was 13.8 degrees, the warmest room in the house was 62.4 degrees. We had the remote (not mounted line-of-sight) set to 76 degrees. Heat from the inside air handler was in the 115/120 degree range. Our oil furnace did not come on last night. I'm planning to install another heat pump (1-ton) to supplement the heat from the 1.5-ton unit when we have these cold conditions. Too much heat loss, not an ideal floor plan all contribute to unequal heat distribution.
Poleikleng
