RYLAND I had the same situation.With solar hot water systems you can not simply turn the pump off or you will damage the system, every time I've worked on a solar hot water system that had a pump fail we had other parts of the system fail as well, it also damages the glycol anti-freeze that is in the panels as the glycol is only good for 240F or so before it starts to brake down.
