Old 01-14-15, 11:56 PM   #14
Clev
Wannabe greenie
Originally Posted by NeilBlanchard View Post
The refrigerator has a double benefit - you don't use the 20W for the bulb, and you then do not have to use more power to remove the heat from the frig. A double win!
If you need an LED for the fridge, you're leaving the door open for too long. If you insist, wait until the existing incandescent burns out; otherwise, the time spent with the door open changing the bulb will probably waste more electricity than you'll gain from running the LED bulb for the rest of the lifetime of the fridge.
Clev is offline   Reply With Quote
