Anyone have a response to this quote? Some context: I am in a very mild Southern Cali coastal climate, I am sealing and insulating the house, it is currently 1472 sqft and will expand to 1900 sqft, power rates are $0.14/kwh for first 307 kwh and then rates start going up until the jump to $0.25 and $0.28 after 610kwh/month. I plan to install solar power. I do not need cooling much more than a couple days a year. This will mainly be for "winter" heating, when lowest nighttime temps will get down to ~40 degrees F.
Scope-Of-Services
1. Furnace: Remove existing (non-functioning) Tempstar gas furnace.
2. Evaporator coil: Install horizontal heat pump fan coil underneath house. Install external drain pan.
3. Condensing Unit: Install heat pump condensing unit in rear yard on 3” high pad.
4. Flue piping: Existing to be abandoned.
5. Ductwork: Adapt to existing flexible ductwork. Install 2 new supply air grilles in floor of living and dining room. Install 2nd filter return grille low on living room wall.
6. Condensate piping: Install condensate pump and piping to approved receptacle.
7. Refrigerant piping: Install insulated refrigerant piping from fan coil to heat pump.
8. Gas piping: Cap off gas line under house.
9. Controls: Furnish and install new Honeywell Focus Pro 6000 digital programmable thermostat.
10. Electrical: Install 2 new 208/230 electric breaker, conduit and wire from meter to fan coil and heat pump.
11. Warranty: Provide manufacturer’s warranty on equipment & 1 year parts & labor.
Amana heat pump equipment:
Fan coil model Heat pump model Tons SEER/EER DB Installed cost
ARUF303016 ASZ13030 2.5 13.0/11.0 72 $6,430.00
ARUF314216 ASZ14030 2.5 14.0/12.0 72 $7,080.00
Amana 80% afue, 60,000 btu’s gas furnace with air conditioning:
Furnace model A/C model Tons SEER/EER DB Installed cost
AMH80603AX ASX13030 2.5 13.0/11.0 72 $6,380.00
AMH80603AX ASX14030 2.5 14.0/12.0 72 $6,780.00
(Includes adapting to flue vent and gas line)
Warranty: 10-yr fan coil and furnace parts, 10-yr heat pump and a/c compressor part. Lifetime furnace replacement if stainless steel heat exchanger fails. Amana 14 SEER units have a lifetime unit replacement if the compressor fails.
Prices include all equipment, materials, tax and labor.
Option # – Permits
Provide city permits.
Cost - Service charge of $75.00 plus cost of permits, licenses & HERS rater.
