The question now, of course, is where would you find such a waveform? As it turns out, it's actually a very good waveform for a power inverter to output
It's also possible to design a generator to output trapezoidal waves, and in fact, the motor/generators in many hybrid and electric vehicles do just that.
You misunderstood the type of inverter. Of course you can make run whatever at whatever waveform in an isolated circuit that isn't interconnected. Aircraft equipment operates at 400 Hz for example. You can't just change the grid waveform or frequency to whatever you want whenever you want. If you want something different.
Look into the future where alternative energy is the norm and rectifier loads like PoL (Point of Load) VFDs are everywhere.
Oh sure. They'll continue to be around. But the movement in the near future is disallowing importation and sales of those harmful equipment without good front-end filtration in North America following the IEC directive model.
http://grouper.ieee.org/groups/harmo...cs/P1495D2.doc
The thing that sets EcoRenovator apart
That's your opinion.
Feel free to not read/post if this thread isn't hands-on enough for you.
