As long as you're not physically wiring the pins together, the arduino software is smart enough to differentiate the digital pins from the analog pins. That shouldn't cause any issues. If you want to test it, just comment out your LCD code and disconnect the LCD.
Do you have a link to the relay shield you're using? Are there any known issues with it?
