WOW! You are into soooooo many projects. Lucky!
Are you going to insulate the barrel? And do you think that debris build up on the coils will be a problem?
You know, this may be the first project to reclaim heat from waste water that I've ever seen. I've read many times that waste water has heat that can be reused, but I've never seen it happen. I wish you luck with the project and please keep us updated.
