Curious question since we're discussing it, how much is good new(not recovered like pretty much what every HVAC tech has today) R22 worth? Edit: Nevermind Xringer's link below shows that they retail it for $340.
Another question, is methane gas similar to R22 or R290? Since the stuff is delivered by pipeline and has certain moisture requirements that I would assume must be more stringent than propane, would this perform better? If someone was careful enough they could vacuum a propane tank after fitting it with a pressure gauge and carefully valve in some from the gas line. Danger level would be similar to a homeowner piping up their own gas dryer and people do it all the time.
