Old 02-13-12, 04:21 PM   #160
BradC
Originally Posted by charlesfl View Post
Great work BradC , thanks so much for your input.
Any further information on drying and reusing filter-dryer?
Sort of. Pulling a vacuum on the filter/drier and heating it with a torch certainly drives off water and contaminants. The vacuum pump oil reeks of mercaptan.
I pull the vacuum down to about 100 microns, and heating the filter drives it up to around 750. I then repeat this procedure until further heating stops the vacuum rising that far. The drier certainly removes mercaptan and water from the Propane and vac/heat removes them from the drier, however I can't really quantify how much. Now I think about it I suppose I could weigh the drier before/after.
I have a small low temperature compressor/condenser unit arriving today that is rated to 200W @ -40C, so I should be able to build a bottle cooler to experiment with water separation.
I also got in contact with Danfoss about their HC range of sight glasses, however have had no luck in obtaining some yet. Nobody seems to stock them anywhere.
BradC is offline   Reply With Quote
The Following User Says Thank You to BradC For This Useful Post:
charlesfl (02-15-12)
