Originally Posted by RobertSmalls
Since you've got more voltage, it will take less current to produce the same output, and the unit will run at lower duty cycle. It probably won't use more power.
I mean, it won't use more energy during the course of a day. It will draw more power and heat your house faster than it would at a lower voltage. However, the controller will respond by running it at a lower duty cycle, or by spending less time at higher power states. Input voltage won't really affect the efficiency of the unit.
