Old 03-15-10, 02:43 PM   #1
Default Off-the-grid with grid-tie inverter?
http://ecorenovator.org/forum/applia...-inverter.html
http://ecorenovator.org/forum/solar-...-inverter.html
If this configuration would actually Start up, it seems like the 12VDC-to-120VAC inverter
would be using very little from the battery, since the grid-tie inverter
would try to make it's voltage just a tad higher..
Anyways, I was thinking this might be the lowest cost way to DIY off-grid power..
If it did work, you could stack the little 300 watt grid-tie (or Enphase) GTIs
and get some nice power-point-tracking from each panel..
Comments please:
Thanks,
Rich
