Your lowered ceiling construction looks similar to what I had to deal with on my old house. On my house all my ceilings have sagged and cracked the old plaster. It turned out to be caused by two problems. The strongbacks that were there were 2x6s and were too wimpy to support the 2x4 ceiling joists. The other problem is that the connections between the joists and the strongbacks were just nails. Over time gravity just pulled the nails loose. Gravity works slowly but it is very persistent.
Assuming you are using Sheetrock and not plastering I wouldn't feel safe from a sagging ceiling with anything less than a 2x6, preferably 2x8 if the joists are 2x4. I can't really tell from your photo what your strongback or joist dimensions are or if it's safely tied to stronger structure above but just thought I'd mention it. Also, I hope you used either screws or small hurricane clips to tie the joists to the strongback.
