Tony,
Where are you located? If live somewhere with a 'real' winter and plan to use the shed year round then insulation should be next on your list.
You might also consider installing a used skylight (craigslist, freecycle, Habitat Re-Store) on the North side of the roof (if the shed is facing the right way) for daylighting.
FWIW,
Tim
