Ah, "mixfoot" is the one with two streams in (usually hot and cold) where "monofoot":
DELABIE - Product :MONOFOOT
... is only one stream in. The price is almost the same, around 250 USD from where I got it from. But as you can see in the picture, those 250 USD should be offset by no need for a faucet. Just a few pipes and joints. Or how you choose to make it, as you can be quite creative using hoses, tubes, pipes ... to get the water from the valve to somewhere above your sink.
