Old 06-28-14, 02:20 PM   #8
oil pan 4
Land owner
Drilling out the jets wont work. There is a single restrictor some where in the shower head. On a detachable shower head its on one end or the other inside that flexable line. Or if its a fixed shower head the restrictor is located just in side the 1/2 inch threads that attatch the shower head to the pipe. The part in question is made with rubber and plastic. When you see the part its pretty obvious its only there to obstruct the flow of water.
I say pull the restrictor, run the shower valve partially open when getting wet or rinsing off, only run it when you actually need it and turn it off when soaping up.
The only time I run it full blast is when waiting on hot water and when I use the shower to wash something other than my self. Such as washing the dog, washing out a trash can, washing the shower its self, filling soapy bucket for mopping or car washing and so on.
Servicetech (06-29-14)
