Old 09-27-21, 05:14 AM   #2
Solar Mike
Is it simply a differential temperature controller? Is there any new tech or features I should be looking for in this area? Variable speed pump control?
Have built a few of these controllers over the years, you need a min. of 2 sensors for differential control, plus a setting for the min. pump on differential, usually about 3-4 degrees Celsius, as there is no point in running the pump when the difference is only a few degrees or less.
For water flow through the panel array: needs to be fast enough for turbulent flow in the pipes to get best heat transfer. Pump size depends a lot on length of your pipes to the array and array size; you want enough flow to get approx a 10 degree Celsius temperature rise out of the array; any higher (less water flow) will loose efficiency through heat radiation.
Last controller I built used a Picaxe 8 pin CPU (program in basic) and a couple of 1-wire temperature sensors DS18B20.
Also have one using a couple of Op Amps, will have a look for the schematic.
Edit: found it, I published this in Silicon Chip many years ago https://www.eeweb.com/solar-hot-wate...mp-controller/
Cheers
Mike
Solar Mike is offline   Reply With Quote
The Following User Says Thank You to Solar Mike For This Useful Post:
Daox (09-30-21)
