Being an ecorenovator is a state of mind. I mainly use incandescent bulbs because dimming is important to me, but I am vigilant about their on time. Often the houses I work in have already had an energy audit where all their bulbs have been replaced with CFL's and they are on all the time. "It's OK. There're CFL's".
My project:
