I was wondering whether a system like this coupled with something that measures the exact distance between two fins, which would have to be precise, and compare the distance with frost/no frost on it. There are many types of frost or snow, some more reflective than others so maybe it would work better with two sensors........or maybe I am making things a bit too complicated. I had a big problem with defrost last year on an ASHP and it is still not resolved.
The evap design i have now will have the coil at about a 20deg angle from vertical so your sensor may work without being in a special compartment as it is under the coil and away from the sun.
