Current air intake temp is 72F, output is 95F.
Current loop temp out is 32F, in is 49F.
The 1 ton unit is using 1.3kw
The 3 ton unit, currently running first stage (2 ton) is using 2kw.
Air temps are on the 3 ton unit. I haven't measured the temps on the 1 ton unit in a while.
Originally Posted by pinballlooking
How much power are you using to heat with?
What is your loop temp? What kind of temp delta through the geothermal heat pump?
