Please see my previous post for the first half of this Arduino source code
Code:
void loop() {
byte s, ScriptCommand;
while (Serial.available() > 0) { // if a command was sent via the serial port, parse it and execute the appropriate action.
ScriptCommand = Serial.parseInt();
delay(1000); // wait for the rest of the command to fill the serial buffer.
switch (ScriptCommand) {
case 1: // dump contents of data file to serial port
DumpLogFileToSerial();
break;
case 2: // add a timestamp to the record
SensorList(true);
SaveTimeStamp();
break;
case 3: // change sensor/logging interval
if (Serial.available() > 0) {
SetCheckInterval(byte(Serial.parseInt()));
break;
case 4:
if (Serial.available() > 1) {
switch (Serial.parseInt()) {
case 0:
SensorList(true); // using the 4,0 command (WITH zero suffix) appends the sensor list to the log file.
break;
case 1:
SetCheckActiveSensors(1, Serial.parseInt()); //enable a sensor by it's list number
break;
case 2:
SetCheckActiveSensors(2, Serial.parseInt()); //disable a sensor by it's list number
break;
case 3: // Enable all available sensors
if (G_SensorQty > 0) {
for (s = 0; s < G_SensorQty; s++) {
G_ActiveSensors[s] = true;
break;
case 4: // Disable all available sensors
G_ActiveSensors[s] = false;
break;
default:
break;
else {
SensorList(false); // using the 4 command (WITHOUT the zero suffix) does NOT append the sensor list to the log file.
break;
case 6: // Pause logging
logging = !logging;
if (logging) Serial.println("\nLogging resumed.");
break;
case 9: // delete the file
DeleteLogFile();
break;
default: //invalid command
//do nothing
break;
G_dString = ""; // reset the data output string if this is to be the first in the list of sensors
if (millis() >= G_TimePoint) {
if (logging) {
G_TimePoint = G_TimePoint + G_LogInterval * 1000;
for (G_CurSensor = 1; G_CurSensor <= G_SensorQty;) {
if (G_ActiveSensors[G_CurSensor - 1]) { //does the user want to log this sensor?
ReadTempSensors(G_CurSensor - 1);
G_CurSensor++;
LogSensorData();
G_CurSensor = 1;
else {
G_TimePoint = G_TimePoint + 1000; // Use a 1 second interval when logging is suspended
Serial.println("\nLogging suspended. Send 6 to resume.");
Serial.println("Interval = " + String(G_LogInterval));
SensorList(true);
boolean ReadTempSensors(byte q) { //read data from sensor q from the array of addresses: G_AddressList[q]
boolean SignBit;
int TReading, Tc_100, Whole, Fract;
byte i, HighByte, LowByte, data[12];
ds.reset();
ds.select(G_AddressList[q]);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(800); // maybe 750ms is enough, maybe not
ds.reset();
ds.write(0xBE); // Read Scratchpad
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
//Serial.print(" CRC=");
// Serial.println( OneWire::crc8( data, 8), HEX);
LowByte = data[0];
HighByte = data[1];
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
if (SignBit) // If its negative
G_dString = G_dString + "-" + (Tc_100 * .018 + 32) + ",";
else {
G_dString = G_dString + (Tc_100 * .018 + 32) + ",";
return true;
void LogSensorData() {
File LogFile = SD.open(LOGFILENAME, FILE_WRITE);
if (LogFile) {
LogFile.println(G_dString); // This is where we actually write all of the sensor data to the file
LogFile.close();
// print to the serial port too:
Serial.println(G_dString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening " + String(LOGFILENAME));
G_dString = "";
return;
void DumpLogFileToSerial() {
File LogFile = SD.open(LOGFILENAME, FILE_READ);
if (LogFile) {
Serial.println("\n<<<READING DATA FILE>>>");
while (LogFile.available()) {
Serial.write(LogFile.read());
LogFile.close();
Serial.println("<<<END OF DATA FILE>>>");
Serial.println("\nResume logging task");
return;
void SaveTimeStamp() {
byte hours, minutes, seconds;
boolean badstamp = true;
if (Serial.available() >= 3) { //check to see if a time was sent
hours = Serial.parseInt();
minutes = Serial.parseInt();
seconds = Serial.parseInt();
badstamp = false;
if (hours > 24 || hours < 0) {
Serial.println("Invalid time format. Hours out of range.");
Serial.println("Hours must be 0 - 23.");
badstamp = true;
if (minutes > 59 || minutes < 0) {
Serial.println("Invalid time format. Minutes out of range.");
Serial.println("Minutes must be 0 - 59.");
badstamp = true;
if (seconds > 59 || seconds < 0) {
Serial.println("Invalid time format. Seconds out of range.");
Serial.println("Seconds must be 0 - 59.");
badstamp = true;
if (!badstamp) {
if (LogFile) {
G_dString = "TIME:" + String(hours) + ":" + String(minutes) + ":" + String(seconds);
if (LogFile.println(G_dString)) {
G_TimePoint = millis();
Serial.println("Timestamp saved: " + G_dString);
else {
Serial.println("Timestamp failed.");
return;
LogFile.close();
return;
else {
Serial.println("FILE NOT AVAILABLE");
return;
else {
return;
else {
Serial.println("Invalid timestamp or none provided.");
Serial.println("hours = " + String(hours) + " Minutes = " + String(minutes) + " seconds = " + String(seconds));
return;
void SetCheckInterval(byte tempint) {
if (tempint > 4) {
G_TimePoint = G_TimePoint - G_LogInterval * 1000;
G_LogInterval = tempint;
Serial.println("Interval changed to: " + String(G_LogInterval));
if (LogFile) {
LogFile.println("INTERVAL = " + String(G_LogInterval));
LogFile.close();
else if (tempint < 5) {
Serial.println("Interval must be 5 seconds or larger.");
return;
void SensorList(boolean w) {// present a list of available sensors
byte i, sc;
for (sc = 0; sc < G_SensorQty; sc++) {
delay(20);
Serial.print(String(sc + 1) + ") ");
if (w) {
if (LogFile) LogFile.print(String(sc + 1) + ") ");
for ( i = 0; i < 8; i++) {
Serial.print(G_AddressList[sc][i], HEX);
if (w) {
if (LogFile) LogFile.print(G_AddressList[sc][i], HEX);
delay(20);
if (G_ActiveSensors[sc]) { // Is this sensor being logged?
Serial.println(" - Logging"); // Notify the user that this sensor is being logged.
if (w) {
if (LogFile) LogFile.println(" - Logging");
else {
Serial.println(" - Ignored"); // Notify the user that this sensor is not being logged.
if (w) {
if (LogFile) LogFile.println(" - Ignored");
if (LogFile) {
delay(20);
LogFile.close();
Serial.println("");
return;
int FillAddressList(int howmanysensorstoadd) {// fill an array with a list of sensor addresses
byte i, s = 0;
byte addr[8];
ds.reset_search();
while ( ds.search(addr) && s < howmanysensorstoadd) {
G_AddressList[s][i] = addr[i];
s++; // increment the count for the next sensor (if there is one)
return s;
void SetCheckActiveSensors(byte c, byte s) {
if (s > 0 && s <= G_SensorQty) { // only do something if the sensor number is in the correct range
if (c == 1) { // User sent the command to enable a sensor
G_ActiveSensors[s - 1] = true; // enable the sensor by setting it true
if (c == 2) { // User sent the command to disable a sensor
G_ActiveSensors[s - 1] = false; // disable the sensor by setting it false
else {
Serial.println("Unknown sensor referenced in command");
SensorList(true);
return;
void DeleteLogFile() {
SD.remove(LOGFILENAME);
Serial.println("FILE DELETED");
return;
