The panels I can get are not huge. They can be easily moved and installed by one person though.
I have a different panel, which I bought used, which is 4'x10' - that one will be used on my house for my solar hot water system.
I don't have fantastic solar access at my house, so it would be difficult to set up all these panels for heating my house. However, I might be able to mount a number of them on my detatched garage roof to help make the garage into heated space.
These panels have the glazing - it appears to be tempered low-iron glass. I have one of the "gaskets" - a rubber strip that goes around the outside edge of the glass and seals up the space between the glass and the aluminum frame.
I did have this solar panel just leaned up against the side of my garage. I had to chip away a lot of ice to get the gasket...
