Originally Posted by Xringer
An amazing conversion! I'm extremely impressed by the performance of that motor.
And the battery life.. That controller was a good investment!
Congrats Doug, on a job very well done!
I think the controller with the foot throttle is what really makes it work good.
the motor has enough to move it around, when I plow the snow I use 3rd or 4th gear, 4th is nice as it's faster. It seems to have a lot of low rpm power and as the rpms go up the power or torque drops off. It will go really fast down hill and slow right up going up the same hill.
I picked the 200amp controller over the 3ooamp mainly to limit the power to the motor. To try to protect it for burning up to quick. I don't know how much more power you would get with the 300amp unit, be nice to try just to see.
One thing I might do is install a another solenoid with a momentary switch, to connect the batteries direct to the motor as a power boost, that would show a power gain if there is any.
Anybody have a line on meters, looking for 2 1/8" round amp and volt meters.
0 to 300 amps, and 0 to 40 or so volts.
Be nice to see what this thing draws when used under different conditions.
