"copper tubing embedded in concrete" is a very bad idea. Many older homes had this & many developed leaks & were abandoned.
Like the skylight saying: There are really only 2 types, those that leak, and those that will leak.
I like the "home run" method using 1/2" O2 PEX limited to 250' each.
Home run means no fittings in floor, all loops start & end at above floor 1" manifolds.
A ball valve at each end of each loop, allows air purging by shutting off all loops but 1 at a time. Also allows for return loop temperature to be balenced. Yes it can be done.
If a loop gets a nail driven into it, that single loop can be shut off at both ends.
I know that your not suppose to use a ball valve for flow balencing (suppose to use a gate valve) but at these low water flow conditions they seem to work just fine.
Where each 1/2" PEX line enters/exits the concrete a 1" 90* grey plastic electrical sleeve is placed, to protect the PEX.
I like some of Blue Bomber Man's logic in post #33 above.
Much more heat is lost along exterior walls & windows, so the hotter source water should be run there 1st. (I think?)
