No big deal I was just curious because I built my greenhouse last year. I could have used a 24’ beam like that one.
I ended up building my own with two 4 x 10 and ply wood glued and screwed together. Then I supported it ½ in the middle.
If I bought a beam like yours I could have done away with the center support.
No Mater what that is a good looking beam.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
