Originally Posted by Clev
Is there a way to do that without caulking it shut? The flow-through really helps in the summer.
I imagined you meant that the glass itself rattled in the frame. Caulking this shouldn't be a problem unless I am imagining this wrong.
For around/between the two sliding frames you can use a product called seal'npeel which is like caulk, but easily pulls off once summer rolls around.
