Old 09-26-08, 04:29 AM   #6
groar
X-Frenchy: very
groar's Avatar
Originally Posted by bennelson View Post
I believe that the concept of how front loader washers use less water is very simple.
Water falls to the bottom. Rotating on a horizontal axis makes all the clothes go through the water, ever if there isn't a lot in there.
On a standard washer, which spins on a vertical axis, the only way to rotate all the clothes through the water is to fill the water level all the way up to the top of the clothes.
I don't remember to have seen a vertical axis washer. Our top loader has an horizontal axis.
Denis.
  • kg saved 06/08-08/09: 1816.9+382.9 (ecodriving / 1420mi not driven) = 2199.8
    (2.66 kg/l diesel)
  • kg saved by 3kWc photo-voltaic solar panels : 187 kg/yr
    (59.1 g/kWh)
  • Long life (>100,000 years) : 2.85 g/yr (0.9 mg/kWh)
  • Short life (<300 years) : 31.7 g/yr (10.0 mg/kWh)
groar is offline   Reply With Quote
