Old 12-06-10, 08:57 AM   #7
hamsterpower
Originally Posted by Ryland View Post
Not sure about those stores, but you can buy the kits online (Tiger Foam is one brand, Handi-Foam is another), price is a little over $1 per board foot, but they do not work well, I used one of the two part foam kits about 6 years back, exact same setup as you can get now, two small tanks with a mixing tip, it worked ok for a while but I would not buy one at the price they are at and I haven't talked to anyone who has tried to use the whole thing who liked it or who would buy them again, they are just to finicky.
The $20,000 setup in a trailer with heated metered pumps seems like a better option, but to get that kind of setup you need to hire the crew to come and use it.
I just used the Tigerfoam kit in my second bedroom. I had everything set up so I could use all the foam in one shot. I was very pleased. I placed the tanks in the bathroom (smallest nearby space) with a small electric heater for about 4 hours at 80 degrees F to preheat them. During application the tanks were in the bedroom with the heater still blowing on them. It took less than 20 minutes to cover the walls in three layers totaling 3-4 inches. While I was spraying I had my dad helping to keep from getting tangled in the hose and shaking the tanks several times. Clean up was easy, much better than after applying Greatstuff foam. I plan to use this kit again when I remodel my kitchen. Next time should go even better as I now know what to expect and know the proper technique.
hamsterpower is offline   Reply With Quote
