Old 01-11-12, 10:04 AM   #7
MN Renovator
MN Renovator's Avatar
Originally Posted by GaryGary View Post
I think you should have just run the 6 inch R30 right over the windows
Gary
*Puts flame suit on* I'm actually considering this, removing the wood blinds(which are dark and pull a ton of heat in) and attaching some drapery to the insulation, gasketing the edge and shoving a 2" sheet of XPS against the glass on the inside. Granted it isn't the outside but its also going to be on the front of the house so I'd like it to look somewhat normal. I'm thinking blocking the light will do more than the R10 will but it should amount to a roughly R12 window assembly that kicks the crap out of the performance of low-E gas. Would this work as well as I think it would?
