Mini-Split line set question
I need to mount the inside unit on the East wall about 10' from the corner. I want to put the outdoor unit on the North all about 5' from the corner. I have plenty of room to run the lines above the ceiling. I just don't know how hard it is to make the turns? Will I have a problem?
The drain from the in-door unit can go out right behind it (on the east wall). I just don't want to put the outside unit there. Can the drain go one way and the copper line set a different way?
thanks
Austin
