We put click flooring in. Very easy to work with. Very convincing appearance, too.
There was a problem with the older stuff as it was a press-board type of core, so if you have a spill, you must wipe it up immediately in case it gets in the cracks and causes swelling of the material.
A friend of mine had to re-do a chunk of his kitchen floor after his water cooler sprung a leak and caused the flooring to get all swollen/lumpy along the seams.
There is also high-traffic, spill-resistant (vinyl), commercial grade stuff available.
