It is safer to use anti freeze. Heat pumps usually sense input temperature and cut out at around freezing but at that stage the return water will be below zero. It can happen if there is flow restriction. Propylene Glycol should be safe enough and would only need about 10% if the pipes are reasonably protected from frost.
