150* output would work, just would take longer to heat the Thermal Accumulator.
"The evaporating temperature can go to maybe 100F, higher if you use a VFD."
As in getting a 3-phase compressor + VFD ?
"You might want to add a thermal sensor to the discharge line. 200F is the maximum limit for most applications, with 180F or so being the preferred maximum."
This would turn off compressor to protect it ?
Is the 20 min on/off cycle to allow the compressor to cool off ?
BBP
