I need to make a few more posts before i can do much
So while i was outside i was thinking but not sure how to test it, maybe someone else is better setup to do this. What about using heavy duty aluminum foil as a heat spreader, I'm not sure if it's thick enough to do much but it would be interesting to see the results of a test, or even multiple layers. It would be extremely easy to work with and the price is not that high either.
