You could, but I'm not sure if you'd really want to(other than a dump load, as mentioned)
Seems like heat would be easier to produce with solar.
If you're grid-tied(and net-metered, depending on rates) you'd be better off sending it to the grid, heating as needed with grid power, and avoiding the storage losses.
If you're off-grid, maybe, I'm not sure how the storage losses compare.
