The tank is going to be garbaged soon, basically when I get my solar application sorted out I'll replace this tank at that time. I will also relocate it so serious insulation is possible. Basically I'm saying I don't want to spend anything on it now.
I did however dig out some of that foil faced bubble wrap that I've had kicking around for 4 or 5 years. I had enough to do 1/2 of the sides and cover the top. so the tank is basically wrapped half way down. I had to really work to fit it between the tank and the furnace. It turns out it was actually touching in a couple of places.
I'll do some checking on the already collected data and then watch the night time standby losses and see if they are spaced further out.
