I do believe that you have found the proper answer to your own dilemma.
Unfortunately, your habit of confusing capacity with efficiency has hidden your discovery of the answer.
Perhaps it would be clarifying for everyone if you would state in clear language what your definition of efficiency is?
Efficiency is work out vs work in, but it's only realistic if compromises aren't made. Attribution of gain to propane wrong, just as attribution of mpg gain to superior "gear" for mpg gain resulting from shifting down to 4th gear from 5th gear while maintaining the same RPM is wrong.
Proper efficiency gain mean increase in mpg, but without losing speed. In the above case, the miles traveled per gallon improvement is mostly from reduction in load from your speed actually dropping.
