Well, when I had the cooler running the couple of afternoons that I did, it was condensing a fair amount of water. Of course, the room was already around 80F and 80% relative humidity, so the dew point was quite high.
Also, I don't have the abnormally high sump pump use, my uncle does. We both came up with the idea while talking at a family get together. This was mostly a proof of concept. I think that you'd have to upsize the a-coil, but you could attain a fair amount of cooling with as much his sump pumps run.
