If I had to choose one that is also the motor I'd choose. Here is the manufacturer's site and the ME1004 description:
ME1004 Brush-Type DC Motor
This is a Permanent Magnet, Brush Type, DC Motor with Neodymium Iron Boron Magnets. The 1" shaft is similar to the shaft on most Lawn and Garden Tractor engines. This motor is perfect for an engine replacement on a Lawn and Garden tractor when converting the tractor to electric propulsion. No motor control is necessary for an engine-swap, but you will need to add a Contactor, Fuse, and 48 VDC batteries. Capable of 200 amps continuous, and 400 amps for 1 minute. The efficiency is 90%.
