Old 02-13-12, 10:21 AM   #6
Piwoslaw
Piwoslaw's Avatar
Also take into account that at temperatures around freezing and with high humidity the HP's heat exchanger may become covered in ice, causing higher power draw, lower heat output, and/or going into defrost mode.
Also, if you hack your own HP, then you can make the HX as large as you like, increasing efficiency.
