Drake, Are you going to heat some of your domestic hot water (DHW)(shower water) also? On the other side of the compresser (cold) I would use a tube in tube HX. Like the one I made. I will give details on how to make it later. How much heat do you need? This DIY heat exchanger only works for smaller systems.
