Or maybe a more appropriate tittle 5 Ton rebuild again. The compressor was liberated from the housing as its too small for the new brazed plate heat exchangers. The chore for the day is to fit up the copper tubing. A bit more fitting is left to be done.
The little 2 ton kept the shop tolerable for most of this cold winter. I didn't want to change it out in the depth of winter just in-case the 5 ton didn't work-out. The nice thing is it kept it tolerable quite inexpensively.
I want to change it out with the 5 ton soon as the nights can still be quite cold and I can get a good idea on its performance.
Randen
