Old 05-29-18, 11:38 PM   #1937
mejunkhound
epoxy path dont hold to pressur heat and chemicals
wow, if you find and epoxy that will hold 410 apllied on external surfaces. let us in on the details of the type AND specific application procedure.
Even initially but especiall after a few months.
Would recommend 15% silphos if you cannot find an epoxy that works. Every DIY needs at least an oxy-propane setup
