Last night I pushed the mower farther than ever on the batteries. I mowed the entire yard (red area on the picture). It also hadn't been mowed in over a week and a half so the grass was quite long. This morning the mower was still charging. A typical cut only uses ~2kWh and this morning it was up to 2.6kWh on the kill a watt. I'm guessing I'll put in at least 3.5kWh which is half the pack capacity. I'd rather not take it down more than that. It is good to know that the entire yard could be mowed (including the yellow area) if I really wanted to though.
