Steve that was a typo it is about 1/2 gallon that is about as low as I was looking for. .40 GPM
(sorry that would be crazy low.)
T-H3-DV-N - 199,000 BTU Natural Gas Indoor Condensing Ultra-Low NOx
Spec sheets.
http://www.takagi.com/media/19483/24...TRGSS01512.pdf
ULTRA-LOW NOX 0.95 ENERGY FACTOR
Power Direct Vent Design
• Exhaust, 3” PVC Venting up to 70 feet or
4” PVC Venting up to 100 feet
I have been very happy with it. The intelligent circulating pump really helps. In my bathroom by the time you use the water warm to hot water is there.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
