Nice work AC, I just started following and noticed the plastic vapor barrier you had used originally. What kind of shape was the insulation behind the visqueen? Is that a little black mold showing up? Even with your carefully applied caulk and sealed up seams, it looks like moisture can still find its way past the vapor barrier, but then gets stuck in there without a way to dry out.
Any thoughts?
