Mikesolar,
This low temperature floor heating information is really great in many respects. Since it is wandering a bit off topic for a Dual compressor heat pump thread, but is especially relevant information for the DIY Hydronic Floor Heating thread, perhaps you could copy your response to THIS LOCATION.
Originally Posted by Mikesolar
There is a move to SCOP over COP because we should be looking at annual bills for the real indicators.
Very interesting... I take it that SCOP is Seasonal Coefficient Of Perfromance? It does make sense that this would be a more useful measure of performance.
With the use of an outdoor reset mixing valve on the floor heating, we can often keep the temp to 24 -28C at milder temps which, with the right HP, could give a COP or 4 or better.
I must admit that I have never heard of an outdoor reset mixing valve before. I just googled the term and came up with
THIS USEFUL PDF DOCUMENT.
It would be very helpful if youu could go into a little more detail regarding the rationale and function of this type of valve.
My friends in europe are putting tubing at 100mm(4") in many cases which until a few years ago I would only do in a sunroom. Now I do it most places. Tubing is a cheap one time cost.
OK, this kind of information has been very hard for me to find but I knew it was being practiced... so I really want to know more...
I certainly see the reason behind why such close spacing is being used, my questions here, regard gaining a full understanding of how it is being done, specifically:
- How to cope with bend radius problems
- What diameter tubing is being used in these installations
- What flow rate is regarded as optimal in these installations
- What are the details if construction for such floors? (poured/not poured?, built up?, the use of high-conductivity materials?, etc)
Lastly, it is very interesting that you are living in Toronto, where your average Heating Degree Days (F) = 7223 (assuming a base temperature of 68 degrees F) or Heating Degree Days (C) = 4010 (assuming a base temperature of 68 degrees C), that folks are successfully using ASHPs.
Many of our readers live in HDD-challenged areas and have a great interest in ASHPs.
Best,
