Old 02-10-22, 02:22 PM   #2
I'm confused. A couple of questions:
What does that pv/t heat pump use for heat transfer outdoors? Directly plumbed refrigerant lines? Water or glycol?
Are you planning to DIY or buy some strange new phase change unit? If it's for dhw only, it wouldn't be much work to modify a smallish window a/c unit.
