I bought the part A and B foam containers on Ebay. No equipment necessary. It pours like water and starts foaming in about 45 seconds. Forms are removable in 15 minutes. Just be absolutely sure your forms are water tight or you will get leaks. I added golf ball sized pieces of Styrofoam in the forms to get the pour foam to go further. Worked great. It comes in 2,4,6 lbs per cuft that's usable for insulation.
